cloud based application to allow user to draw irregular polygon
If i want to deploy fusion 360 on cloud allowing users to draw irregular shapes mainly polygons, which api (objectarx?) should be considered and whats best way for having such application scale for many concurrent users.
Thanking in advance
BrianEkins
Fusion 360 isn't currently a viable solution for what you described.  The API is strictly limited to the desktop version of the application which can only be run in a local desktop, not on the cloud.
I've seen some weird workarounds that people have attempted with varying success but I think attempting anything like that will just lead to frustration.
Brian Ekins
Thanks a lot Brian for your inputs.
If some one intends to have application like mine in mind, what autodesk api can be used, If i am not wrong much of Autocad360/Fusion 360 is supposed to be  cloud based solutions, correct me if i am mistaken.
How should i approach.
BrianEkins
AutoCAD is currently supported and they've announced that Inventor will be available on the cloud using the Design Automation capability on Forge.
Brian Ekins
