Export SketchPoint Coordinates in csv file
_fabschke_
_fabschke_
I want to export coordinates of a point (more points in the future) to a csv-file.
I am not an experienced coder, but even with help of google and some friends I couldn't figure it out.
I tried the in python included csv module, csv.DictWriter etc. but i always get the same error.
OSError: [Errno 30] Read-only file system: 'coordinates.csv'
I tried moving the directory of the .py file to different paths, where I know i have write rights but still the error persists.
 #Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback, csv
app = adsk.core.Application.get()
ui = app.userInterface
pntEntity = ui.selectEntity('Select a sketch point', 'SketchPoints')
pnt = adsk.fusion.SketchPoint.cast(pntEntity.entity)
fields=['X-Coord','Y-Coord','Z-Coord']
with open(r'coordinates.csv', 'a') as coord_csv:
writer = csv.writer(coord_csv)
writer.writerow(fields)
writer.writerow('{0}'.format(pnt.geometry.x))
JeromeBriot
pass the full path of the CSV file to the open function.
The execution path is not the same as the one where your py file is stored.
Try this small example:
import os
def run(context):
    ui = None
    try:
        ui.messageBox('{}\n{}'.format(os.getcwd(), os.path.dirname(__file__)))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
_fabschke_
Wow, that was easy!
Yes that worked!
Thank you very much
karimgrase
For exporting points coordinates to a csv file, i use python add-in you can download from github,
you find it searching for username kantoku and go to repository
Fusion360-ExportSketchPointsCoordinate, or click here: https://github.com/kantoku-code/Fusion360-ExportSketchPointsCoordinate
fivallesgarcia
Observer
Observer
I just checked the code you uploaded and it is not correct. Somehow I don't get the coordinates of the construction points.
