[API BUG] Application.documentActivated Event do not raise
akonovalenko
Message 1 of 8
akonovalenko
Application.documentActivated Event does not raise when switching between Design and Drawing documents.
At the same time Application.documentActivating Event works fine.
In attachment you can find a test script and a short video which describes the issue
Replies (7)
Message 2 of 8
JeromeBriot
Did you try to execute this sample program: Application Event API Sample API Sample ?
On my machine, the documentActivated event works perfectly.
Message 3 of 8
akonovalenko
Yes, I am. Maybe it is a platform-dependent issue? I am working on Windows 10 environment.
And as you can see on my screencast the Application Event API Sample API Sample script does not raise documentActivated and documentDeactivated events when I switch between Drawing and Modeling tabs.
Message 4 of 8
thomasa88
I see the exact same problem. I tried the API sample linked above.
Result:
* Drawing to Design or Design to Drawing: Only Activating and Deactivating events
* Design to Design: Activating, Activated, Deactivating and Deactivated events
2.0.8624
Active Plan: Fusion 360, Personal
Windows 10 (18362)
Message 5 of 8
thomasa88
Note: This makes it very hard to hide/show a panel depending on the document type.
Message 6 of 8
thomasa88
Has there been any progress on this issue? I have multiple add-ins where I have had to hook on to e.g. CommandTerminated to work around this.
Message 7 of 8
thomasa88
Sorry for spamming. Here is how to work around it in the mean time, I think (likely making Fusion 360 a tiny bit more slow with each add-in doing this, as the UserInterface.commandTerminated handler will trigger on every select and small user action).
def command_terminated_handler(args: adsk.core.ApplicationCommandEventArgs):
    # PLM360OpenAttachmentCommand, CurrentlyOpenDocumentsCommand are workarounds for DocumentActivated with Drawings bug.
    if (args.commandId in ('PLM360OpenAttachmentCommand', 'CurrentlyOpenDocumentsCommand')):
        # document activated
Message 8 of 8
zxynine
I just created a drawing document and swapped just as done in the video it appears as though this is no longer a problem. cool.
