[BUG] How to clear up Fusion palette cache?
akonovalenko
akonovalenko
After some time of using my custom palette, Fusion for some reason marks my palettes as Native and do not allow to manipulate with hem thru the script commands. Screenshot_42.png
even worse I get an error when trying to delete them
I even try to remove Fusion from my PC then install it back and guess what? - My custom palettes are still there and they are still native 😞
So, my question is: Where Fusion stores information about custom(native) palettes and how that information can be removed?
akonovalenko
Looks like an issue in the NULastDisplayLayout.xml file from
Mac OS:
Macintosh HD > Users > *** > Library > Application Support > Autodesk > Neutron Platform > Options > *** > NULastDisplayedLayout.xml
Windows:
C:\Users\****\AppData\Roaming\Autodesk\Nuetron Platform\Options\***\ NULastDisplayLayout.xml
Which contains a record for my custom palette
            <Area LayoutPattern="Row" Placement="Bottom" Rect="182,1084,617,4">
              <State Size="1491,435" StateType="Absolute"/>
              <Area Contents="Palette" Dockable="True" MinimumSize="150,61" Name="MyTestPalette_3" Placement="Bottom" Rect="0,1080,435,0" Resizable="True" Stretchable="True" Visible="False">
                <Parameters Proxy="True"/>
              </Area>
            </Area>
When I removed the file or removed the record from the file - Fusion stops tracking my palette as native, and I can remove it and create a new one.
akonovalenko
Does anyone know how to modify or remove NULastDisplayLayout.xml file programmatically from the PY script?
It seems that Fusion 360 creates a new file each time when it closing when all scripts already stopped. So any manipulations with the file before do not have any sense, because the file will be overwritten...
JeromeBriot
Here is a code that removes the XML file:
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
import platform
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        if platform.system() == 'Windows':
            dataPath = os.getenv('APPDATA')
        else:
            dataPath = os.path.join(os.path.expanduser('~'), 'Library', 'Application Support')
        xmlFile = os.path.join(dataPath, 'Autodesk', 'Neutron Platform', 'Options', app.currentUser.userId, 'NULastDisplayedLayout.xml')
        if os.path.exists(xmlFile):
            os.remove(xmlFile)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Here is another code that renames the XML file as a backup file (safer):
import os
import platform
def run(context):
    ui = None
    try:
        else:
            bakFile = xmlFile.replace('.xml', '.bak')
            if os.path.exists(bakFile):
                os.remove(bakFile)
            os.rename(xmlFile, bakFile)
    except:
        if ui:
JeromeBriot
I just faced a similar issue. The error message was: "RuntimeError: 3 : Palette with same id has been existed."
I had to force Fusion 360 to quit while testing a new add-in. So I think that the file NULastDisplayedLayout.xml became corrupted. The palette I created was not closed properly and the corresponfing <Area> tag in the XML file was not removed.
I closed Fusion 360 and I manually removed the section in the XML file. Everything is OK now.
