Chain select sketch elements
The ability of auto-selecting a chain of connected sketch elements, for example whan patternig or mirroring is one of those little  additions that I've enjoyed in more mature and admittedly more expensive CAD packages. Not sure a screencast is realy necessary but here it is.
10 Comments
Chain select is also handy to find breaks that might have inadvertantly been made, since the chain will stop at any opening.
Regardless of votes, this is a super no-brainer.
Yes.  Selecting using ctrl or shift is OK with a sketch that has five segments, but if the profile has 20 segments it gets frustrating very quickly.
Select Chain and Select Tangent within sketches are both very useful in SW.  An improvement over SW, however, would also let you choose to select a start and end segement and auto-select everything in between.
TrippyLighting
I'd like to add that this already seem to be working perfectly when selecting edges for chamfering or filleting.
thepirate1
You can see my comments in https://forums.autodesk.com/t5/design-validate-document/moving-profiles-in-sketch/m-p/6032067/highli...
I don't know what is chain select, or how it would work, I only know that in practice, you have to select every single segment of anything you want to move, and that is very tedious.  (select with square marquee is just a disaster for connected overlapping things like rectangles). Also, I bet you could make a huge mess of constraints on individual segements if you really want to constrain a whole profile (sketch object?) like a rectangle.
For the same reason that you want to be able to manipulate bodies as whole entities in 3-D, It is really obvious that you should be able to at least select (better constrain and otherwise manipulate) sketch entities such as rectangles.
Thanks for listening,
-TPC
keqingsong
Status changed to: オートデスク審査落選
We have this planned for one of our March updates. Stay tuned!
haughec
This is in progress.  Tracking it internally as FUS-17224.
keqingsong
You will be able to do this in tonight's update! http://www.autodesk.com/products/fusion-360/blog/june-22-2016-update-whats-new
TrippyLighting
YeeHaw!
scottmoyse
This should help find breaks in complex profiles to an extent as well.... well that is only if there is more than one break.
