Bend body
Bend body
106 Comments
KirillChepizhko
Ability to bend bodies in model mode.
Tags (1)
Dunndor
I completely agree with this feature to be added as soon as possible. There are so many times where i want to kitbash already made parts and squash stretch and bend them around.
This would be such an awesome ability, a whole set of deformers would be amazing.
schneik-adsk
Status changed to: 実装予定
cekuhnen
yep all for it
blender also has many of such great deformers.
herzinj
Status changed to: オートデスク今後検討
Wow, very popular idea!!
I'm passing this one along to the dev team to see how we can make this possible.  Hopefully this is something that we can add relatively easily and get added into Fusion 360 quickly.
Good morning;
We are a Product Developer in Florida. To date we only have 3 products in the market so we do not have the budget for SolidWorks so we have been searching for a more affordable solution. So far we LOVE Fusion 360. However our products are mostly metal which means a lot of sheet metal work. It is viatal that we have the ability to "bend" materials.
Currently we have to use Google Sketchup to accomplish this which stinks.
I would love to know if this is something comming sooner rather than later so we can make the decission to purchase Fusion 360. (right now we are on the trial but this is a sticking point for us unfortunately)
Thanks so much,
Brooks
Bend only?
what about twist, shear, taper, bulge, squash?
cekuhnen
Fusion has nothing to deform like basic twist tape bend
but also flow along surface or bend along curve would be nice.
I rather build something flat and then bend it into shape then modeling it bend.
TrippyLighting
Sounds like some of the modifiers in Blender 😉
deyop
Deformers for Form and Solid objects is a feature that is in our backlog (FUS-5191) but we certainly would like comments about specific workflow that users would like supported.
cekuhnen
From Rhino to Alias many have such deformers as well.
Twist bend etc and flow over a surface.
Twist obviously is usefyul when you can build something linear and then you twist it
pipes, cylindrical wisted design like in bottles etc
Bend is also very usefyl when again it is easier to build something linear and then bend it into shape.
Bent plywood and other things
I would love to see a twist parameter in the sweep tool; without it designing true helical structures is impossible.  You can get close by lofting between lots of sketches, but this is cumbersome and doesn't yield true twisted shapes; when viewed from the 'top' (in the case of a spiral staircase), edges connecting the profiles are straight lines instead of the curves they should be.
Bend , twist, bulge.  Thanks
bverboort
Yeah I'm drooling over a feature like this, particularly for flexing/bending living hinges (as seen in plastic parts) and with the bodies, attached to the living hinge strips, swinging around as the living flex hinge is bent.
Although I found the sweep path can pretty much work for my living hinge need, by changing the sweep path and letting history after that update.  Really cool.  It looks like other bodies made on the sweep end faces reorient too.
I woud add that it would be nice to have a modifier that allows to choose a tessalation type.
To be more specific, I think that it would be essential to have at least Voronoi tessalation and Delaunay tessalation.
We need the tools to choose how will Fusion solve Convex hull problem.
In Rhino's CageEdit, a cage of control points is placed around an object. You can pull the points around to deform it:
KirillChepizhko
Cage edit is exactly what we want in fusion !!!!
