Point to Point moves need to be captured in design timeline.
Couldn't find a forum for "Bugs", so as a feature...
When you have the timeline design history enabled, moves do not seem to be captured when a point to point move is used.  This leads to errors if you rewind and replay a design history, because parts are not put into the correct place.    This seems to happen if the move is a simple point to point, or a complex rotation followed by a point to point.  (What I wanted to so was rotate a copy 180 degrees, then alingn a point to another feature.)
This does not happen when the move is a simple translation & rotation. Those seem to be captured in the timeline correctly.
3 Comments
herzinj
herzinj
Status changed to: 実装予定
i agree that all actions should be captured in the timeline some way or another, though it might be some time until this one makes it there.  We will keep you updated on the status change when this gets closer to being added to the software.
herzinj
