Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Trying to create a non-uniform sweep for complex curvature/surfacing
3 REPLIES 3
bmartinek
359 Views, 3 Replies
I'm trying to make some complex surface geometry, for the end of a bike light. I've looked into a sweep, loft, patch and revolve but none seem to do the job, or I am not using them correctly. Most likely the latter.
Any suggestions to create this would be greatly appreciated. I've created two profiles to help describe it.
Screen Shot 2019-05-15 at 1.56.43 PM.pngScreen Shot 2019-05-15 at 2.03.16 PM.png
3 REPLIES 3
Beyondforce
in reply to: bmartinek
Hey @bmartinek ,
Could you please explain "none seem to do the job"? Please make a screencast and show us exactly what you are trying to do and what doesn't work.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Fusion 360 Hardware Benchmark: TESREG.com
Visit us on Facebook Page Facebook community
YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
g-andresen
It´s important that the rails are connected to the profile (ellipse and point).
The rails are designed as splines and run tangentially into the end points and turning point.
end capend cap
günther
screencast with details
bmartinek
in reply to: g-andresen
Thanks much Günther! Very helpful to see the correct approach.
Technology Administrators
