I'm trying to make some complex surface geometry, for the end of a bike light. I've looked into a sweep, loft, patch and revolve but none seem to do the job, or I am not using them correctly. Most likely the latter.
Any suggestions to create this would be greatly appreciated. I've created two profiles to help describe it.
Solved by g-andresen. Go to Solution.
Hey @bmartinek ,
Could you please explain "none seem to do the job"? Please make a screencast and show us exactly what you are trying to do and what doesn't work.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Fusion 360 Hardware Benchmark: TESREG.com
Visit us on Facebook Page / Facebook community
YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
It´s important that the rails are connected to the profile (ellipse and point).
The rails are designed as splines and run tangentially into the end points and turning point.
günther
