I'm trying to make some complex surface geometry, for the end of a bike light. I've looked into a sweep, loft, patch and revolve but none seem to do the job, or I am not using them correctly. Most likely the latter.
Any suggestions to create this would be greatly appreciated. I've created two profiles to help describe it.
Solved by g-andresen. Go to Solution.
Hey @bmartinek ,
Could you please explain "none seem to do the job"? Please make a screencast and show us exactly what you are trying to do and what doesn't work.
Cheers / Ben
Did you find this reply helpful? If so please use the Accept as Solution or Kudos button below.
Fusion 360 Hardware Benchmark: TESREG.com
Visit us on Facebook Page / Facebook community
YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
It´s important that the rails are connected to the profile (ellipse and point).
The rails are designed as splines and run tangentially into the end points and turning point.
end cap
günther
