Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Forma Streets Not Showing Up in Revit
1 REPLY 1
kcrawford9G2U2
233 Views, 1 Reply
Hi! When working with Forma and the add-ons such as the terrain and building geometries, they export into Revit very nicely. However the property boundaries and the street linework does not. I found a work around to get my desired property boundaries to show up Revit, however I cannot figure out how to get the street linework to export to Revit. Has anyone had success with this?
Thanks!
Tags (3)
Labels (2)
1 REPLY 1
smilksh
in reply to: kcrawford9G2U2
Thanks for the question!
We support roads in Revit 2024 only.  If you are running an older version of Revit you will not see them.
Hopefully this helps!
-Heather from Forma
Forma Design Contest
