Will it be possible to automatically apply solar panels according to the size of the roof, which will not need to be laboriously produced in other programs?
Solved by andrea_marie_festy. Go to Solution.
Could you please elaborate on what you mean about "laboriously produced in other programs" and what you would like to achieve?
Currently Forma is providing a solar energy potential analysis. In this analysis you can see the total solar energy/insolation over a year. Based on this energy you can configure roof coverage and solar panel efficiency to see an estimated number of potential electrical output for solar panels on these surfaces.
If I understand your question correctly the answer is, no you don't need to draw or produce the solar panels, but they are not automatically generated either. We are currently not supporting detailed drawings of a solar panel rig, but you can get an indication of the amount of electrical output you could generate from using solar panels.
Did this answer your question?
