Hi! When working with Forma and the add-ons such as the terrain and building geometries, they export into Revit very nicely. However the property boundaries and the street linework does not. I found a work around to get my desired property boundaries to show up Revit, however I cannot figure out how to get the street linework to export to Revit. Has anyone had success with this?
Thanks!
Thanks!
Solved by smilksh. Go to Solution.
Thanks for the question!
We support roads in Revit 2024 only. If you are running an older version of Revit you will not see them.
Hopefully this helps!
-Heather from Forma
-Heather from Forma
