Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Revit Version Reporting
One area that has been a pain everywhere I've worked, is figuring out what projects are in what version of Revit. With ACC I would think that it would be easy, but it surprisingly has no such feature and even finding the version of a single project is still not intuitive.
On a project level, having a field for the project that shows it's revit version, would be great. A way to auto add a prefix of the revit version on a model would be even better.
On an admin level, it would be great to report all projects revit versions in a spreadsheet like format that can be filtered. Taking it a step further, it would be good if there were rules that could be applied that would color projects that are too far outdated for Autodesk support (maybe yellow for 3 years and red for 5).
This seems like something that would help improve upgrade rates as it would be easier to spot projects that are way too outdated.
28 Comments
curtisridenour
How is this not a thing yet? Be really nice to filter projects by Revit version. It would help to ensure upgrading projects to the new version a lot easier.
ASanchezDES
Please add a column to the Account Admin Projects list that says what version of Revit the cloud project folder is locked to. This would save a lot of time since you wouldn't need to click into the folder and navigate to a subfolder with a Revit model (our models have the Revit version as part of the file name) in it.
J.Cline
Project Admins are able to "see" what version the revit models are in an ACC project site, by going into settings and using the Revit Upgrade tool.  It will scan the project for models, list the current version, and provide a list of potential upgrade versions available.  To my knowledge, regular project members cannot tell what version a model is, by way of viewing the model on ACC.  We have shared team members that work on many projects, we have projects that upgrade versions at appropriate times when needed.  Sometimes multiple, similar projects are in different versions, one may be legacy and in an older version, the newer projects may be in a more current version.  We try to name the Revit file with the version used, but sometimes an upgrade happens and file names are not updated, some of this is user error/ driven - I get that.
But it would really help the working world, if the revit version of a BIM file is simply shown in a column on ACC, or in the details of a file if you select the model and view it, possibly under the 3-dots menu, for example.
Currently, people play the "What version is it game!" and just open various versions of revit until they find the version that displays the model.
Thank you!
JC
curtisridenour
Bump, this is critical. Please do this. A list of all projects and their version is critical.
tyronethompson
This would be great reporting metric. I should be able to see as an account admin or a project member, how many projects I have in each version.
lionel.kai
It would be nice to be able to see the Revit version without having to download the model. It's possible as a Project Admin, but our clients would be crazy to make us all admins just for that LOL
Ric_Weber
I was coming here to put in this exact idea.  Since ACC knows what version the Revit files are, just create a column in the project list that can report that information!  Seems like something that should have been set up from the get go!
craigjonnson
As Autodesk is degrading cloud models for 2021 and below, this is super crucial.
ACC admins need the ability to see which version of revit are the files contained in each folder. Currently the only way to find out is to open each project, go to Docs/ settings and click on the Revit tab to see if upgrades are available.
This is extremely tiresome, and makes little sense as the data is already 'known' by the system.
It would be helpful for Admins to see this as we need to deal with all projects and all files. opening individual files and individual projects takes forever.
Also, it would be good to be able to see whether revit cloud models exist in each project, which makes the project 'version-less'
The available info displayed is incomplete
KsmithTU58F
This has now become an even bigger concern, especially with Autodesk beginning to phase out support for 2021 cloud models. Thankfully, we don’t currently have any projects on 2021, but this will become a serious issue next year.
Autodesk really needs to stop introducing blockers without providing the tools to manage them.
At a minimum, we should be able to:
  • Filter projects by Revit version
  • Bulk-upgrade multiple projects at the same time
  • Convert cloud models back to standard Revit models
Without this functionality, managing projects at scale becomes increasingly difficult and risky.
mtoeppYBU54
Observer
I was coming here to suggest the exact same thing. It's annoying to have to open every version of Revit to figure out which year the project is in. Especially when if you pick the wrong year, you have to upgrade to the current year and cannot downgrade.
chad.martinLZHG7
Make. This. Happen. A separate thread from 2020 was requesting this and it still hasn't happened. I have 100's of projects to survey; assessing individually is not optimal.
curtisridenour
@chad.martinLZHG7 haha not optimal is an understatement.
lfarrell-arch
YES!  We need to see Versions.
Some other threads linked.... so you can go vote on them too and see the ideas as they got posted.
https://forums.autodesk.com/t5/bim-360-ideas/show-currently-used-revit-version-in-projects-2023-or-2...
I posted about it this year again but in the wrong forum!
https://forums.autodesk.com/t5/forma-for-construction-forum/need-revit-year-on-admin-dashboards-to-k...
@ignacio_martinezillera posted about it and I commented on it
https://forums.autodesk.com/t5/forma-for-construction-ideas/display-revit-version-as-a-standard-colu...
@angelica.rodriguez.3d posted about it with better graphics...
https://forums.autodesk.com/t5/forma-for-construction-ideas/ability-to-see-revit-version-of-acc-proj...
Now I just want there to be an "upgrade all projects button"
Select by year, "bulk upgrade".
None of this sitting and clicking through through projects one at a time business.
And also a "hold" button where you can make the projects live in limbo, in "service mode".
Not archived, services still on, but not available to users, so you can fix stuff and not have people mess with it. The equivalent of the little triangle road cones while your car is broken down.
-Liz
curtisridenour
Done and Done @lfarrell-arch
chad.martinLZHG7
There is a workaround:
Go to File > Options > Cloud Model > toggle on "show projects in all versions of Revit software versions at New Revit Home." Then in the "New Revit Home" , click on "Autodesk Projects", and then your company's root folder. It will list all projects in your company's Forma cloud and their version. You may have to have Hub Admin rights to see them.
This should be available in Revit 2023 and onward.
lfarrell-arch
This is exactly what I've been looking for - thank you for making it more visible!
Thank you @chad.martinLZHG7 !
ASanchezDES
@chad.martinLZHG7 This is great suggestion if you want to see all your projects within the Revit software.
I'm hoping they add a sortable column on the ACC/Forma website that displays the specific year each project cloud folder is locked to.
j.andrews5VMSD
Having an exportable report from the ACC/Forma Website with all the projects in a group with the Revit versions would be good as well. I'm finding myself having to go through hundreds of older projects and verifying each with the area managers of 5 different divisions to make sure we want to upgrade them or if we no longer need them.
aholversonTNWAG
Observer
What would be ideal is a Revit Cloud Project Launcher that was a central location to find all cloud models and when selected it opens up the model in the correct version of Revit.
