EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Autorouter not routing (Video Included)
1 REPLY 1
447 Views, 1 Reply
Hey, so I'm trying to use the autorouter feature and for some reason it isn't routing my airwires when I connect connect the signals. The only time I've used the autorouting was back in the 6x version and the airwires were generated from the schematic. Well this board doesn't really require much of a schematic so I opted to just make the board without one. Below is a video that helps to show the issue that I'm having. Any help on the matter is appreciated!
1 REPLY 1
one-of-the-robs
I don't use the autorouter myself but at a glance it looks like your dimension layer outline is not being correctly picked up. All your pads are off the board according to Eagle's assessment so the autorouter can't do anything with them.
I'd also suggest that even that board contains enough to be worth drawing a schematic but that's a separate issue.
