EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Managed libraries keep disappearing -- Eagle 9 on Mac
14 REPLIES 14
Message 1 of 15
traykoff
1929 Views, 14 Replies
EAGLE 9.0.0 on a Mac...
Open app, open Library Manager, add a few managed libraries.  They download and show up in "Managed Libraries".
I then go to add parts from these libraries to a schematic, and then save the work.
Close app.  Restart.
All my Managed Libraries are gone in the control panel, and I have to re-import them to be able to search and/or use parts in them.
The libraries are still in my home directory under  ~/Library/Application Support/Eagle/lbr, however they are all put into folders adsk.eagle_library_NNN where NNN is some sort of serial number.
This isn't correct behavior of the app, is it?  I have seen this happen on two different Eagle on Mac installs...
Thanks,.
T
14 REPLIES 14
Message 2 of 15
david.mellis
in reply to: traykoff
You're right, that's not the correct behavior. The record of the managed libraries is kept in the EAGLE RC file (~/.eaglerc on Mac). Is it possible that file is being lost or overwritten somehow? Can you share a copy of your EAGLE RC file?
When the libraries disappear, are you able to re-download them from the library manager (available tab)?
Message 3 of 15
traykoff
in reply to: david.mellis
Hi.  I have deleted .eaglerc, and everything in ~/Library/Application Support/Eagle, so that it should be a fresh start.  I started up Eagle 9, logged in, and the problem persists.
After restarting Eagle, all my managed libraries are gone.  So that didn't fix it.
A workaround that I am using is to:
cp /Applications/EAGLE-9.0.0/cache/lbr/*lbr /Applications/EAGLE-9.0.0/lbr/
This basically disables the Managed Library feature.
Taavo
Message 4 of 15
david.mellis
When you quit EAGLE after creating / installing managed libraries, do you see entries like the following in your EAGLE RC?
Lbr.Managed.1.author = "EAGLE PCB"
Lbr.Managed.1.has_urns = "1"
Lbr.Managed.1.modified = "0"
Lbr.Managed.1.name = "19inch"
Lbr.Managed.1.path = "/Users/mellisd/Library/Application Support/Eagle/lbr/adsk.eagle_library_79/19inch.lbr"
Lbr.Managed.1.urn = "urn:adsk.eagle:library:79"
Lbr.Managed.1.version = "1"
Do they remain when you restart EAGLE and then quit again?
Message 5 of 15
traykoff
No such lines in .eaglerc after adding a few managed libraries and then quitting the app.
In fact:
$ grep -i managed .eaglerc
Lbr.ManagedCacheInstalled.9.0.0 = "1"
[[ Just that one line exists ]]
Message 6 of 15
david.mellis
Strange. Is it possible something has changed the value of your $HOME environment variable (used to locate the EAGLE RC file)? Do you know what it's set to?
Are you running EAGLE from the command line and passing it any command-line arguments?
Message 7 of 15
traykoff
Strange indeed.
I deleted .eaglerc, and Eagle created it again so I think it is going to the right location for this file.  No, I am running in from the Mac Search.  Not a command line...
Message 8 of 15
david.mellis
Any chance you can record a screen capture of the process? I'm not sure what might be happening and seeing the process might provide some clues.
Message 9 of 15
david.mellis
Also, do you have the same problem with a previous version of EAGLE (e.g. 8.7)? That should help isolate what's causing the problem.
Message 10 of 15
traykoff
Thank you for checking into this.
I have this problem on 8.6 also.  I also have this with installs on two separate machines; both of which are running Mac OS High Sierra.
I have installed 9.0 on a Windows machine.  It works very differently, to say the least.
I can send some screenshots later if helpful.
Message 11 of 15
david.mellis
Screenshots would be helpful. If you don't mind posting it, it would be helpful to see the contents of your EAGLE RC as well. I'm baffled as to what's going on here, so the more information, the better.
Message 12 of 15
traykoff
I found a Mac that this works on, and what I think is a big hint to the problem.  The Mac that this "works" on has a case-insensitive file system, while the ones that it does not have case-sensisitive file systems.
I can send my .eaglerc, but can't figure out how to do it on this forum.  Do you want to send your email so we can transfer files, etc. related to this issue?
Message 13 of 15
david.mellis
Thanks for tracking that down! I'm assuming the problem is indeed the case-sensitive filesystem; I don't believe I've tested that case on Mac. No need to send the EAGLE RC file. I'll get this fixed ASAP.
Message 14 of 15
traykoff
Thanks!!
Message 15 of 15
traykoff
I did a dtruss on this, and sure enough it appears that this is the problem:
819/0x65ba:  stat64("/Users/taavoraykoff/Library/Application Support/Eagle/lbr/adsk.eagle_library_169009/Nordic_nRF.lbr\0", 0x7FFEEFBFA528, 0x0) = 0 0
  819/0x65ba:  stat64("/users/taavoraykoff/library/application support/eagle/lbr/adsk.eagle_library_169009/nordic_nrf.lbr\0", 0x7FFEEFBFA598, 0x0) = -1 Err#2
What's the chance of getting this fixed soon?
Thanks!
