Dynamic Blocks Forum
text rotation
9 REPLIES 9
Message 1 of 10
715 Views, 9 Replies
text rotation
I NEED TO MAKE A DYNAMIC BLOCK IN WHICH I HAVE ATTRIBUTES AND WITH A ROTATION BUT I WANT THAT MY TEXT ALWAYS REMAINS HORIZONTAL EVEN IF THE ROTATION CHANGES. THANK YOU SO MUCH
J'AI BESOIN DE FAIRE UN BLOC DYNAMIQUE DANS LAQUELLE J'AI DES ATTRIBUTS ET AVEC UNE ROTATION MAIS JE VEUX QUE MON TEXTE RESTE TOUJOURS HORIZONTALE MÊME SI LA ROTATION CHANGE .
MERCI BEAUCOUP.
9 REPLIES 9
Message 2 of 10
hwalker
Make an Annotative text style and tick "Match Text Orientation to Layout". See the image below. You'll also probably need to make the block annotative as well.
Howard Walker
Left Handed and Proud
Message 3 of 10
in reply to: hwalker
thank you ,
I tried what you suggested to me but it doesn't work as you see in the photo and I need to have the text as an attribute so I won't have to enter the editor each time  to change the text
Message 4 of 10
Libbya
Add a chained point parameter.  Add a move action associated with the chained point parameter and add the attribute to the move action's selection set.  Add the chained point parameter and do NOT add the attribute to the rotate action's selection set.  If you need further assistance post the block.
Message 5 of 10
in reply to: Libbya
I tried what you told me but I find that it does not work so I said Annotation 2020-01-30 150607.png maybe the parameter or the action that I had chosen was not the right one for that I will leave you the photo of my block
Message 6 of 10
Libbya
in reply to: Libbya
Quit posting pictures and post the block instead.
Message 7 of 10
in reply to: Libbya
HERE IS THE BLOCK
Message 8 of 10
Libbya
I guess you missed it when I said *chained* point parameter.
Message 9 of 10
Libbya
in reply to: Libbya
Message 10 of 10
in reply to: Libbya
thank you soooo much  😁 it was very helpful
have a nice day
Forma Design Contest
AutoCAD Beta
