@amarinXG8V6 wrote:
or if that is to complicated.
I'm afraid that all this together will be "to complicated" for AutoCAD (for some reasons).
Perhaps you will have a change if you can split the problem in several smaller issues.
(One of the main problems: In AutoCAD you can not modify/calculate the values of an array [number of items, distance of items, ...], if you additonal want/need to modify the geometry of the source element(s)).
Jürgen Palme
