Dynamic Block with stretch and array action
torpass
torpass
Hello everyone,
I'm on AutoCAD, trying to create a simple "grid" in section, that is a dynamic block, and that the base can be stretched and the top can be arrayed, everything in a single grip. The problem is that I can't figure out how to get the array object be in pair with the stretched rectangle object, because I need to set the value in millimetres that I will insert on the grip. Is it possible to do that?
Here's the dwg, and a screenshot of an example of how the block should behave.
Thanks in advance
Ed__Jobe
How about this version. I added a second polyline with a move action chained to the stretch action. I also changed the stretch to an increment action. No need to specify dims. Just drag how many elements to array.
Ed
How to post your code.
satoshiq
I did not see you set the chain action to yes?
satoshiq
I thought I coppy all of your action, but I don't know how it just not work.
