- Mute
- Permalink
- Report
Hello everyone,
I'm on AutoCAD, trying to create a simple "grid" in section, that is a dynamic block, and that the base can be stretched and the top can be arrayed, everything in a single grip. The problem is that I can't figure out how to get the array object be in pair with the stretched rectangle object, because I need to set the value in millimetres that I will insert on the grip. Is it possible to do that?
Here's the dwg, and a screenshot of an example of how the block should behave.
Thanks in advance
Link copied
