Multiple visibilty parameters in a dynamic block
mehdi-guida
Message 1 of 22
mehdi-guida
Hi
Is there any way to use multiple visibilty parameters in a dynamic block (by Lisp routine OR ...)?
Thank You
Replies (21)
Message 2 of 22
Ed__Jobe
It's not very clear what you're asking for. Do you already have parameters in your block and you want to access them in code or are you asking how to create them? It helps if you attach your block to your post.
Ed
How to post your code.
Message 3 of 22
mehdi-guida
Thank you for respond.
When I want edit or design my dynamic block i am allowed to use visibility parameter only one time.
I will received error message "Visibility parameter already exists in block definition" if I want to use visibility parameter for second time. But I've heard  some Lisp routine can solve it.
Message 4 of 22
Ed__Jobe
Again, post your block and tell us how you want the block to work. What you want to be visible and what you don't want visible.
Ed
Message 5 of 22
mehdi-guida
Thank you.
Attached is a drawing include a simple dynamic block. I created a visibility parameter for small and big lines.
I want to create same visibility parameter for small and big circle and square.
Message 6 of 22
Ed__Jobe
All you have to do is make a visibility stat active, then make the objects you don't want to show, invisible. Use the button in the Visibility panel or run the BVHIDE command.
Ed
Message 7 of 22
mehdi-guida
Thank you
But I need 3 individual visibility parameters.
One for lines, one for circles and one for squares. and each one work individually.
Message 8 of 22
Ed__Jobe
You can only have one visibility parameter, but you can have many visibility states, e.g.
big line, big circle, big square
big line, sm circle, big square
big line, big circle, sm square
3 cubed number of states
Ed
Message 9 of 22
j.palmeL29YX
You can do that with a Double Lookup.
An example is attached. Let us know if you need more help. (just in moment I'm in hurry)
Jürgen Palme
Message 10 of 22
j.palmeL29YX
Here a more detailed suggestion.
How to create a Double LookUp parameter you find in the (still) pinned post above >>click<<
Jürgen Palme
Message 11 of 22
neil
Solution above is a nice way switching on and off multiple combinations of more than 2 visibility states, however it takes a lot of time to get there. Is there no workaround to having more than one visibilty parameter, it would be so useful. I have a component drawn as a dynamic block, the component has various hatched finishes, and also has 3 optional lighting details. In an ideal world I would have one visibilty parameter for the finishes, and one for the lighting options, and they would work independently of one another in the same dynamic block.
Message 12 of 22
j.palmeL29YX
No, only one visibiity parameter is allowed (read also message #8).
And the "workaround" to get the whished behavior was described above (double lookup).
Jürgen Palme
Message 13 of 22
neil
Ok thanks. I'll look for another solution. Double lookup is Ok for 3 variables, but I have 8-10 variables per component, and 30 components to author. The length of time that would take is too much for this job I think.
Message 14 of 22
h_s_walker
@neil Have you tried a block properties table?
You can fill in the combinations in excel and then copy and paste into the table
Howard Walker
Left Handed and Proud
Message 15 of 22
neil
I think that if I were combining linear or polar parameters that would work, since I can have multiple parameters in the table and asign different combinations of values, but because there is only one visibilty parameter, I cant see a way to combine different visibility states. I guess its an understandable limitation, if there was more than 1 visibility parameter, and there was overlap between the objects selected in combined visibility states it would result in error. It would however work very nicely if there wasn't overlap.
To better explain uploaded one of the blocks with fewer variables. 3 materials & 4 lighting options resulting in 12 visibility states. Ideally I would have 3 visibility states for the materials and 4 for the lighting features with another parameter
A complication is that this is a 3d model with 2d dynamic properties, but I dont think that affects the problem.
Message 16 of 22
h_s_walker
@neil I would read the pinned topic How to Make a Double Lookup - Autodesk Community - AutoCAD. That would do exactly what you want. It takes a little more work to do, but I've reattached your drawing
Howard Walker
Message 17 of 22
neil
Thanks for the help, yes also saw old YouTube vid on 4 way visibility basically doing the same thing from KaDe King (https://www.youtube.com/watch?v=cYZGh70ttF8) which is longer but explains it nicely. Lot of work but looks to be the best solution cheers.
Message 18 of 22
neil
FYI there is a fast and dirty solution xclipping the block, then using flip to hide the contents outside the xclip. Doesn't behave that well though, the flip states need to be changed before the other actions or it seems to break. XCLIPFRAME set to 0 for this to work. attched. Will use the double Lookup method thanks for help
Message 19 of 22
neil
error in that last block posted, attached correct works well with xclip
Message 20 of 22
vcocoraP86VJ
I see what you did there, you flip the desired geometry then turn it invisible. Can be used for any number of objects within the block.
Nice!!!
