Link Distances
Link Distances
carl.coghill
Link Distances
carl.coghill
I am setting up a dynamic block and I would like two distances to be linked to a third.
The first two distances need to be 1/4 of the third (overall) distance. Objects would then be linked to these points so that they are always placed at 1/4 span of the overall span - regardless of it's length.
Is this possible in dynamic blocks? So far I have only used dynamic blocks for basic uses.
EDIT: file attached
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
j.palmeL29YX
One of several possibilities is using parametric constraints.
see attachment
Jürgen Palme
h_s_walker
Not got full autocad here, but it sounds like you need to look at parametric constraints
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Howard Walker
Left Handed and Proud
carl.coghill
That appears to be exactly what I was trying to do.
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
ojuris
You can do the same without parametric constraints
