AutoCad Blocks
AutoCad Blocks
eng_raednofal
Observer Observer
AutoCad Blocks
eng_raednofal
Observer
Observer
Whole of the drawing is one block and when i tried to explode it disappear.
jayhar
When using EXPLODE or BURST on a block in AutoCAD, the block disappears or a good portion of it vanishes.
Click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
eng_raednofal
Observer
Observer
i Checked your solution and same result.
Click here
Thanks You
Jayhar.M.J
jayhar
use the REGEN3 command to regenerate the visual style and make objects re-appear again
Can you please upload AutoCAD 2013 format after delete all layout???????
eng_raednofal
Observer
Observer
The problem is not that the layout disappear, the problem that i can not explode the layout
Please advise.
j.palmeL29YX
Explode a Layout ?? What do you mean? I never ever exploded a layout.
How did you create the layout, perhaps using the viewbase command?
What do you really want to do?
cadder
Jürgen Palme
jayhar
You first and last thread something mismatch, please provide step by step. why you explode layout??
