curved lines
curved lines
Message 1 of 15
curved lines
I have a question......this is the first time this has happened.......well into a design I must have touched a key, but I don't know which.  The result is now all circles and curved lines appear more like polylines.   I tried going back a few entries but it only got worse.  I tried like one suggested to REGEN ALL....it does not seem to work either.
Must I start over again or is there a way to recover the original work?  I checked by drawing a circle on an new page and the circle comes out the same...rough and wobbly.
Thanks,  John
Replies (14)
Message 2 of 15
h_s_walker
At the command line type options.
Choose the display tab. Check the highlighted are in the image below. Make both numbers larger. I usually set mine at 20,000
Howard Walker
Left Handed and Proud
Message 3 of 15
Not to sound like a complete newbie ...but where is the "display tab"?
Message 4 of 15
h_s_walker
As I said at the command line type OPTIONS. You will see a dialog box pop up. Click the tab which says DISPLAY
Howard Walker
Message 5 of 15
OK found it.........my list there is     1000- ARC and circle smoothness
        8- Segment polyline curve
        0.5 Rendered object smoothness
                                                               4- Contour lines per surface
I put Arc and circle smoothness up to 20,000 but the circles are still very wavy.....I use a lot of circles to generate tangents etc
Message 6 of 15
h_s_walker
I don't have full Autocad, but I would suggest upping the numbers on the other two values as well.
Howard Walker
Message 7 of 15
No it is not changing the circle or curved lines smoothness......straight lines are perfect....there is still something else...I have full 2018 Student version.
Thanks anyways...I will keep trying
Message 8 of 15
pendean
Community Legend
Community Legend
Use REGENALL command, do your circles now look correct?
Message 9 of 15
No all the curves and circles are bumpy....so I guess it is now a little worse
Message 10 of 15
j.palmeL29YX
Type in the command line GRAPHICSCONFIG and show us a screenshot of the Graphics Performance Window.
(Or play yourself with the settings in this window).
cadder
Jürgen Palme
Message 11 of 15
It will take me too long to figure out a screen shot..but  there was a list of options for the graphics card
Smoothline display
Adv. material effects
Full shadow display
Per-pixel lighting
Uncompressed textures..........they are all in ON position
Message 12 of 15
j.palmeL29YX
One of the most important information you have withheld from us so far: which graphics card?
And: Set the system variable HQGEOM (I miss it in your graphic settings) to 1 andcheck what happens.
cadder
Jürgen Palme
Message 13 of 15
Sorry....Radeon R5 M420  2GB.........tried the HQGEOM ...at 0 change to 1......"not supported"
I am just confused why this has been OK for over a year and started acting up only today.  I am hesitant to continue with the wobbly lines in case they will affect all the drawings.
Message 14 of 15
j.palmeL29YX
And again an important information, which we rather accidentally and incidentally get to know. Man Frustrated (SCNR).
Has the graphics driver possibly been updated by an automatic update?
cadder
Jürgen Palme
Message 15 of 15
Not that I know of.......I have not updated anything for awhile other than Microsoft's regular ones...........
