curved lines
curved lines
해당 사항 없음
666 조회수
14 답변
1/15 메시지
curved lines
해당 사항 없음
I have a question......this is the first time this has happened.......well into a design I must have touched a key, but I don't know which.  The result is now all circles and curved lines appear more like polylines.   I tried going back a few entries but it only got worse.  I tried like one suggested to REGEN ALL....it does not seem to work either.
Must I start over again or is there a way to recover the original work?  I checked by drawing a circle on an new page and the circle comes out the same...rough and wobbly.
Thanks,  John
667 조회수
14 답변
답변 (14)
2/15 메시지
h_s_walker
At the command line type options.
Choose the display tab. Check the highlighted are in the image below. Make both numbers larger. I usually set mine at 20,000
Howard Walker
Left Handed and Proud
3/15 메시지
해당 사항 없음
Not to sound like a complete newbie ...but where is the "display tab"?
4/15 메시지
h_s_walker
As I said at the command line type OPTIONS. You will see a dialog box pop up. Click the tab which says DISPLAY
Howard Walker
5/15 메시지
해당 사항 없음
OK found it.........my list there is     1000- ARC and circle smoothness
        8- Segment polyline curve
        0.5 Rendered object smoothness
                                                               4- Contour lines per surface
I put Arc and circle smoothness up to 20,000 but the circles are still very wavy.....I use a lot of circles to generate tangents etc
6/15 메시지
h_s_walker
I don't have full Autocad, but I would suggest upping the numbers on the other two values as well.
Howard Walker
7/15 메시지
해당 사항 없음
No it is not changing the circle or curved lines smoothness......straight lines are perfect....there is still something else...I have full 2018 Student version.
Thanks anyways...I will keep trying
8/15 메시지
pendean
Community Legend
Community Legend
Use REGENALL command, do your circles now look correct?
9/15 메시지
해당 사항 없음
No all the curves and circles are bumpy....so I guess it is now a little worse
10/15 메시지
j.palmeL29YX
Type in the command line GRAPHICSCONFIG and show us a screenshot of the Graphics Performance Window.
(Or play yourself with the settings in this window).
cadder
Jürgen Palme
11/15 메시지
해당 사항 없음
It will take me too long to figure out a screen shot..but  there was a list of options for the graphics card
Smoothline display
Adv. material effects
Full shadow display
Per-pixel lighting
Uncompressed textures..........they are all in ON position
12/15 메시지
j.palmeL29YX
One of the most important information you have withheld from us so far: which graphics card?
And: Set the system variable HQGEOM (I miss it in your graphic settings) to 1 andcheck what happens.
cadder
Jürgen Palme
13/15 메시지
해당 사항 없음
Sorry....Radeon R5 M420  2GB.........tried the HQGEOM ...at 0 change to 1......"not supported"
I am just confused why this has been OK for over a year and started acting up only today.  I am hesitant to continue with the wobbly lines in case they will affect all the drawings.
14/15 메시지
j.palmeL29YX
And again an important information, which we rather accidentally and incidentally get to know. 실망한 남성 (SCNR).
Has the graphics driver possibly been updated by an automatic update?
cadder
Jürgen Palme
15/15 메시지
해당 사항 없음
Not that I know of.......I have not updated anything for awhile other than Microsoft's regular ones...........
