Hi I am creating a dynamic block that has for legs one in each corner and each leg can only rotate 90 degree's, the legs are also telescopic so I have used the polar stretch parameter, its worked perfectly well on three legs with the minimum and maximum angles of 0 to 90, 90 to 180, 180 to 270 BUT when i try to limit the last leg to 270 to 360 or 0 it will not work, can someone tell me where I am going wrong please.
Solved by Ed.Jobe. Go to Solution.
Hi no it just resets back to 0 and there's no limitations on the action it can rotate 360 degree's, I fact I can only set it to whole numbers.
I'm not at work now, but you should be able to enter fractions of a degree. Check your UNITS>angle precision is set to. You might also try 0 to -90
Hello @sscott1664
Please share the dynamic block, so that I can check it.
@sscott1664 See the attached drawing and the image below
Howard Walker
Share the block file. As hwalker demonstrated, setting the minimum angle of the polar parameter to 270 and the max angle of 360 works fine. I can't even guess what you have done to make it not work.
