I've created a dynamic bloc and I want to add hundreds of them to a table using excel. But each dynamic block has a distance and Angle related to a leader in the block. How can I insert this into the drawing including this information, in addition to the attributes? (see properties window for special attributes below)
Second question. I have some attributes which are multi-line. I get an error when I paste this into the command window.
(command ".-insert" "Junction_Status" "180295.529,669980.692,0.000" 1 0 1 2 3 4 5 6 7 8 9 10 11 12 13)
Error:
I tried adding a double space " " between multi line attributes to say <Done> to pass onto the next atribute, but it does not work.
Thanks for the help!
