I am trying to create a stud partition dynamic block that can have varying lengths and widths – see attached file.
Generally, the block works but the partition is to be insulated and I am using a hatch to indicate this.
The hatch needs to be scaled to maintain its look as either the width or length of the partition change. The initial distance multiplier for objects associated with this scaling is 6, (600/100mm as drawn within the block). However, following a change in the width or length of the block this scaling changes i.e. 750/250mm = 3. Therefore, whenever the length or width of the partition is changed again the scaled insulation hatch and associated objects do not correlate.
Does anyone have an idea of how this can be solved to maintain the relationship between the scaled hatch and associated objects over multiple changes?
Thanks!
