adjust distance between columns in dynamic array
S_S_SS
Message 1 of 13
S_S_SS
Hi everybody..
i make a dynamic block and i make dynamic array ... i want to adjust distance between columns because it variable in each block .
how can i do that ever with lisp or any way
thanks in advance
Replies (12)
Message 2 of 13
Libbya
You can use an array object and then use formulae in the properties of the array object combined with constraints.
Message 3 of 13
S_S_SS
Excuse me sir
Can you tell me more details to understand your idea?
Message 4 of 13
Libbya
I gave details in your other threads.
Message 5 of 13
S_S_SS
thanks sir ...
you help me a lot....
Message 6 of 13
fercbaLQF6F
Community Visitor
Community Visitor
Hi! @S_S_SS thank you for your video. I did the same dynamic block but i have a problem. I need to have a minimum and maximum distance between 0,60 and 0,40 meters to create my wall sistem (wood framing).The distance will depend on my project. So the thing is that i need to create a block capable of adjusting to the size of the wall and establish automatically the distance dividing it without the need of making a manual calculation of which i will have between columns. Hope this is clear. My parameter is to get columns that have a equal distance between 0,4 and 0,6 in a strech.
Message 7 of 13
j.palmeL29YX
@fercbaLQF6F wrote:
... i need to create a block capable of adjusting to the size of the wall and establish automatically the distance dividing it ... that have a equal distance between 0,4 and 0,6
That is so (0,4 <= distance <= 0,6) not possible.
You should decide it you want either a minimum distance of 0,4 OR a maximum distance of 0,6.
Attached an example (of course with other dimensions) how that can be done.
If you need a more detailed help post your block please.
BTW:
The author of the video was @Libbya   😉
Jürgen Palme
Message 8 of 13
muhammad_bisma71
Observer
Observer
Thanks for your tutorial.. but i want to ask something, how i can resize the object in this array with some parameter in dynamic block? So it will be automaticly change (size) because the size of the object is one of variable to change in dynamic block.
Thanks.
Message 9 of 13
muhammad_bisma71
Observer
Observer
Thanks.
Message 10 of 13
j.palmeL29YX
It is not possible to change dynamically the dimensions of the source object(s) of an array in dynamic blocks.
In some rare (and simple) cases you can use cheating work arounds to get the whishes result. But before offering such solutions we must know the current task - what geometry is given and what do you want to achieve.
Jürgen Palme
Message 11 of 13
MMcCall402
You can't dynamically change the sizing of the objects being arrayed.
You can however have multiple arrays and then use a visibility state to choose the one you want.
You could also have the object being arrayed as a block and then redefine that block as needed.
Or even some combination of the two above.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 12 of 13
muhammad_bisma71
Observer
Observer
Thanks for the answer
Message 13 of 13
muhammad_bisma71
Observer
Observer
