Grip position after stretch and rotation operations
maksym.khilo
maksym.khilo
Dear colleagues,
While I was designing a dynamic block for reference, I've run into the next problem that I can not solve. Block has few actions - rotation (for the whole block itself) and stretching (for the reference line), it works well until you:
1. rotate it
2. stretch it
3. rotate it again
4. rotation grip is losing its position
Can you give a bit of advice is it possible to fix such behaviour of rotation grip?
Block is attached (2018 format).
ojuris
hi!
don't move rotation parameter
maksym.khilo
Hi ojuris,
My mistake, that I asked not clear enough in the first message. Is it possible to maintain a rotation grip position in the center of the circle after stretching and rotation operations?
ojuris
I think that you can't move rotation grip but you can use polar parameter
maksym.khilo
Super! That is exactly what I needed and as a bonus lower amount of operation in the block.
