- Mute
- Permalink
- Report
Good afternoon Folks!
Today's question is a doozie!
I have a detail from an older drawing (not drawn by me) with a block showing a door. BUT, if you single click the block, it allows you to change the height, width, and inner frame detail sizes by simply typing in the size you want it - as is, it's a 3ft x 7ft door, but if you single click and move your cursor to the top left, for example, it shows a number of 84". If you then type in 96, it stretches the door the additional 12". It seems to be a cool little feature, the problem is I want to change one of the details of the block, but if I explode and re-block it, I no longer have the auto-stretch properties available. I need to adjust it so the connecting point of the 2 diagonal lines remains in the middle position of the door.
I am not familiar with this type of thing, I've never come across it before, is anyone out there familiar with this type of thing, and do you know how to add in the change I'd like to make?
Many thanks,
MarkF
