Dynamic Blocks Forum
How can I modify the level head size and block text attributes for multiple blocks at once
3 REPLIES 3
AB_CAD
107 Views, 3 Replies
Please see the attached cad drawing. How can I modify the level head size and block text attributes for multiple blocks at once
Tags (1)
Labels (1)
3 REPLIES 3
AB_CAD
in reply to: AB_CAD
here is the cad file
Brock_Olly
in reply to: AB_CAD
If you want to edit it for all blocks, you can use 'battman' to change the attributes of the entire block.
If you only want to change specific blocks, I think you could use the 'GATTE' express tool (not in autocad LT)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Change-values-of-t...
MMcCall402
in reply to: AB_CAD
Select all the blocks you want to edit and look to the properties window.  All common properties and attributes will show there and can be edited all at once.  (note: they'll all be the same after the edit)
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
AutoCAD Inside the Factory
