Is there a way that I could drive a nested blocks value through?
No. Aside from entering block editor and editing a nested block you are out of luck. Also, keep in mind that if you edit a nested block it will update in all existing insertions of the host block.
I was hoping i could use a formula to look up into the parent block or something along those lines.
