Dynamic Blocks Forum
Dynamic Elbow
10 REPLIES 10
Message 1 of 11
pascal_khattar
863 Views, 10 Replies
Dynamic Elbow
Dear Users
i have created a dynamic elbow (See attachment) i need to add a control to be able to modify the size of the elbow (outer radius) while maintaining the small radius constant and the edge (color 8 line) values
can someone give it a try, it seems that i'm stuck.
Regards
Tags (2)
10 REPLIES 10
Message 2 of 11
Libbya
in reply to: pascal_khattar
Here's a fairly complicated version that eliminates the constraints.  While it is complicated there are a few dynamic block concepts that are worth learning that are demonstrated nicely in this block.  See attached.
Message 3 of 11
Thank you libbya for ur response will take a look at it when i'm at my desk.
Regards
Message 4 of 11
Libbya
in reply to: Libbya
Here's a constraints version that seems solid.  See attached.
Message 5 of 11
pascal_khattar
in reply to: Libbya
thank you very much
both your blocks are perfect, i will try to reverse engineer your solution maybe i can try to understand your approach
thanks again!
Message 6 of 11
Libbya
Here's a screencast of the step-by-step for the constraints version.  It is considerably simpler than the dynamic parameters/actions but I prefer using dynamic actions/parameters as their behavior is more consistent.  Dynamic parameter/action version screencast will follow.
Message 7 of 11
Libbya
in reply to: Libbya
Dynamic parameters/actions screencast.
Message 8 of 11
pascal_khattar
in reply to: Libbya
i would like to thank you again i just did what you showed me in screencast! it worked perfectly
the construction lines were very helpful and the way you split the line into 3 segments to be able to constraint the edges was a great solution,
thank you a lot for your help.
Best Regards
Message 9 of 11
How to maintain relationship of width of elbow with radius of the arc
Eg. R=W
R=W/2
"Revit Lies in the tension between what we want to do and what can be done!"
Message 10 of 11
Libbya
in reply to: Sujan.Maharjan
Sujan are you trying to ask a question or make a statement?  In either case, I don't know what you are trying to say.
Message 11 of 11
Sujan.Maharjan
in reply to: Libbya
dynamic_elbow.pngdynamic_elbow.pngMaintaing relationship between radius of arch and width of the elbow.I kind of figured out .Is there a solution with a associative hatch and rotation grip now?
Forma Design Contest
