Dynamic Blocks Showcase: Share Your Favorite Dynamic Blocks
Victoria.Studley
Autodesk Autodesk
Message 1 of 313
Victoria.Studley
Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Replies (312)
Message 81 of 313
vigan
Hi Chris,
Could I possibly get the Section Line dynamic block?
My email is: [email protected]
Thank you
Vigan Smiley Happy
Message 82 of 313
There are hundreds of dynamic blocks I've made of the years that I'm particularly proud of but a lot of them are very specific to our company and some I don't want out into the public because I'd like to be selfish 😉 but here's one I wouldn't mind sharing as I bet it could be useful to some people.
It's a block for the short backset 32mm Lockwood 5582 mortise lock. It has multiple views of all of the multiple different configurations possible for furniture (plate hardware).
Message 83 of 313
Victoria,
What a great thread post for all AutoCAD users especially beginners and students or users eager to learn how to develop their Dynamic Block knowledge. Also it is very good how these can be shared with the community.
Message 84 of 313
tim_crouse
Here is a power cable (AWG) that folks may find useful.
Best Regards
Tim
Message 85 of 313
jtohill
if someone is having trouble with wipeouts try using dwg to pdf to print with.
Message 86 of 313
tim_crouse
Nice Work!
Could you offer a little guidance on how you create teh sub menus?  I do not seem to be able to get into what looks like a block table inside your block.  I figured that is where all the magic is happening.
Tim
Message 87 of 313
jtohill
graphic scale imperial. insert at the dimscale of the drawing (ex. 48 for 1/4", 96 for 1/8"). also north arrow insert 1:1 will adjust to cannonscale.
Message 88 of 313
s.borello
You can download DWG Trueview and save it down yourself if you want.
Message 89 of 313
Francisco_Melo
Here is a Composite Panel, you may find useful.
Best Regards
Francisco Melo
Message 90 of 313
tim_crouse
I am not seeing any dynamic functionality in the posted block.
Message 91 of 313
bwhisenhunt
Here is a block I created for our office to help with doing sections and details.   We kept running into cases where things were getting skewed due to errant stretches, etc. so this block solved a lot of those issues.   It is a dynamic metal stud wall with the following abilities:
  • You can stretch to any length/height you need.
  • You can select the stud size
  • You can turn the bottom track on or off (this also works well with base details by flipping upside down and turning the track off which is now at the top.
Message 92 of 313
tim_crouse
Message 93 of 313
tim_crouse
Here are some updates to dynamic hardware  and unistrut pieces.
Hope this saves some folks time.
-Tim
Message 94 of 313
tim_crouse
Here are updated dynamic hardware and struct pieces.
I found many small issues re;ated to wipeouts and plotting.
Blocks have been organized on borders
Included STB plot style for folks that want to see what the plotted intent on my side was.
Added separate hardware wipeout for better control
Added separate hatching layer for better transparency and p;otting control.
Named plot style laid out to provide multiple resolution options to avoid black smudging hardware in plotted outputs regardless of the viewport scale (thats the intent anyways :))
-Tim C.
Message 95 of 313
nice block but where is it?
Message 96 of 313
ryan-lehtonen
They are in the ZIP and in Papespace…  Nice blocks
Lehtonen
Message 97 of 313
thank you too much
Message 98 of 313
tim_crouse
a couple blocks used for cabinet elevations
Based around STB plot style.
-Tim C.
Message 99 of 313
tim_crouse
Here is an updated dynamic door block
Message 100 of 313
jtohill
@neaton wrote:
Nice block, @ChrisMackayOpticad. Do you have problems with the wipeouts printing correctly: solid black or gray instead of white?
Nancy
Nancy if you are having trouble with wipeouts print using (DWG to PDF) as the printer.
John Tohill
