Dynamic Blocks Showcase: Share Your Favorite Dynamic Blocks
Victoria.Studley
Autodesk Autodesk
Message 1 of 313
Victoria.Studley
Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Replies (312)
Message 61 of 313
tim_crouse
Here is a panelboard front view used to create electrical elevations
Message 62 of 313
AC Link Box that I and my colleagues use at work (Aeronautical Ground Lighting Diagrams for UK airports mainly), it has all the different setups that we need and when Combined with the Link Arrows/Cabling Works like a charm.
It is currently the second largest block in the Collection and was the Most annoying of the lot to do due to just learning some of the principles behind it and Deciding that I would use 1,2,3 for the lookup values instead of something a bit more meaning full.
Designed in AutoCAD 2014 and currently used in AutoCAD 2017.
Message 63 of 313
Message 64 of 313
tim_crouse
The elbows are size selectable.
Due to set array increment property I decided to prove a scale gauge inside the straight FMC.  That way the user can
perform a scale ref operation to get what ever size conduit they need and still use a single array control.
Message 65 of 313
tim_crouse
Here is a set of dynamic conduit box connectors.
It is missing set screw type and Steel Compression type >> perhaps an update will be in this drawings future when I find time.
Message 66 of 313
tim_crouse
Here are a few tags I use in construction project drawing packages.
Hope they save folks some time,  they are setup to be auto linked into a sheet set or when used as a standard inserted block you can simply blow the line away in the attribute.
These are setup for a named plot style, to use with CTB would take a little experimenting.  If you use CTB and you want to test these blocks you will need to create a new drawing used the named plot style dwt as your system is most likely setup to create new drawing with a CTB plot configuration.  You will not have access to the STB file from inside a CTB based drawing (with going through extra steps)
-Tim C.
Message 67 of 313
vrod_2000
I got tired of all of the Instrument Stanchion symbols, so made this one.
It has every kind (I think) of Instrument stanchion in it that I have ever used.
I made a screencast of it below.
https://autode.sk/2U413Ar
Message 68 of 313
vrod_2000
Here is a screencast of an armoured level gauge/magnetic level gauge.
Message 69 of 313
Here is a block I made for a sections. It can flip and rotate.
And Show Like section, Check this out.
Message 70 of 313
tim_crouse
Good stuff, woks good.
Have you considered adding a wipeout to it so it can be placed anywhere on the sheet?  You could add a wipeout ON/ OFF in your vis states.
-Tim C.
Message 71 of 313
neaton
Instead of a wipeout, I recommend using a solid hatch color 255,255,255 which prints white. Some plotters, printers and pdf writers still print wipeouts as solid black fills. I don't see it too often, but often enough that I recommend not using them.
Nancy
-Tim C.
Message 72 of 313
Thank you, Nancy! I still run across this issue as well, but never thought this fix.
Message 73 of 313
s.borello
You can download DWG TRUEVIEW for free and down-save dwg files.
Message 74 of 313
tim_crouse
Here are a few steel framing pieces ( unistrut ) channels and hardware some folks may find useful
As always, hope they save you some time.
-Tim C.
Message 75 of 313
tim_crouse
Here is an example of a set of dynamic concentric arcs.
Best Regards
Tim
Message 76 of 313
josue.garay85
Here some cable tray blocks that I made last week.
Message 77 of 313
tim_crouse
Nice stuff!
Message 78 of 313
josue.garay85
Thank you.
Message 79 of 313
josue.garay85
I tried using a block properties table.
Message 80 of 313
tim_crouse
Here is a dynamic Rebar block.
It developed in imperial but inserts correctly into metric drawings as well.
It uses named plot style
To change the internal object colors:
Create a blank drawing
Rename the block
change layer info as required, merge coloring etc...
this way you can show new and existing rebar in the same drawing
Lineweights are set thin as I use this type of object in zoomed in details
Best regards
-Tim
