Hi guys,
I wonder if is some way how to connect stretch action with visibility state?
If I change length of line, automatically change assigned visibility state. Is it possible to do it?
Thank you for respond.
Solved by hwalker. Go to Solution.
See the attached drawing for an example. You need to understand how double lookups work.
Howard Walker
If someone read this, here I found links explain how double lookups works :
https://forums.autodesk.com/t5/dynamic-blocks-forum/how-to-make-a-double-lookup/m-p/5785708#U5785708
