Hi guys,
I wonder if is some way how to connect stretch action with visibility state?
If I change length of line, automatically change assigned visibility state. Is it possible to do it?
Thank you for respond.
Solved by h_s_walker. Go to Solution.
See the attached drawing for an example. You need to understand how double lookups work.
Howard Walker
If someone read this, here I found links explain how double lookups works :
https://forums.autodesk.com/t5/dynamic-blocks-forum/how-to-make-a-double-lookup/m-p/5785708#U5785708
