How can I make the indertion point to stay in the middle of the streched block?
Solved by Libbya. Go to Solution.
Move all your objects so the centre of them is at 0,0. Also post the drawing so we can actually have a look at what your block is doing.
Howard Walker
Post your actual block. Then we can have a look at it.
Howard Walker
edited the original post and attached to it.
Thanks for taking your time to look at it.
Here you go
You can either change the basepoint of the stretch from endpoint to midpoint and add another stretch action.
Or you can add a base parameter and move it by half of the stretch.
See the two blocks in the drawing below
Howard Walker
