Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Dynamic Blocks Forum
Dynamic block grip (origo) doesn't move when streched
7 REPLIES 7
Message 1 of 8
szuri62SSR
414 Views, 7 Replies
How can I make the indertion point to stay in the middle of the streched block?
7 REPLIES 7
Message 2 of 8
h_s_walker
in reply to: szuri62SSR
Move all your objects so the centre of them is at 0,0. Also post the drawing so we can actually have a look at what your block is doing.
Howard Walker
Left Handed and Proud
Message 3 of 8
szuri62SSR
in reply to: h_s_walker
the grip doesn't stay in the middle, or centered
Message 4 of 8
h_s_walker
Post your actual block. Then we can have a look at it.
Howard Walker
Message 5 of 8
szuri62SSR
edited the original post and attached to it.
Thanks for taking your time to look at it.
Message 6 of 8
h_s_walker
Here you go
You can either change the basepoint of the stretch from endpoint to midpoint and add another stretch action.
Or you can add a base parameter and move it by half of the stretch.
See the two blocks in the drawing below
Howard Walker
Message 7 of 8
Libbya
Message 8 of 8
szuri62SSR
in reply to: Libbya
Thank you for the solution, really appreciate it !
AutoCAD Inside the Factory
