Dynamic Blocks Forum
Dynamci Blocks with steel angle shapes
23 REPLIES 23
Message 1 of 24
falconbird
6408 Views, 23 Replies
falconbird
       Trying to create a steel angle dynamic block. Attached is a drawing showing the steel angle with its table showing sizes and length. Can't get it to stretch. Also don't know if I will have a problem with the radius of all the angle sizes. Using the sample files as a template. Please help me file in the blanks.
23 REPLIES 23
Message 21 of 24
m_rogoff
m_rogoff
@Anonymous
 C and MC shapes.
 Cross section, front, side views
@Anonymous
 C and MC shapes.
Message 22 of 24
m_rogoff
in reply to: m_rogoff
m_rogoff
I've attached a file containing steel sections and shapes, plus misc supporting blocks (weld, bolts, base pl, shear tab, etc) that I created using the same method @Libbya outlined in this thread. All steel sizes are from an AISC spreedsheet imported in the properties table.
I no longer use AutoCad so I am passing this forward and hoping someone else can use these!
--mr--
--mr--
Message 23 of 24
falconbird
falconbird
Thank you.
Thank you.
Message 24 of 24
Thanks for the blocks passing on.  Might have to modify them for layer properties and line types but the mechanics work great.  Thanks again.
AutoCAD Inside the Factory
