Dynamci Blocks with steel angle shapes
falconbird
Message 1 of 24
falconbird
       Trying to create a steel angle dynamic block. Attached is a drawing showing the steel angle with its table showing sizes and length. Can't get it to stretch. Also don't know if I will have a problem with the radius of all the angle sizes. Using the sample files as a template. Please help me file in the blanks.
Replies (23)
Message 2 of 24
dbroad
I suggest you start playing with much simpler concepts until you understand the process.  You used a block table instead of a lookup table.  The block table is used to relate dimensional parameters but you used dynamic block parameters instead.   The dynamic block parameter sets you placed were backwards and the actions were not set.
If you want to keep the block table, add dimensional parameters and constraints.  If you want to use dynamic block parameters, then start from the insertion point and work away from that.  Set up the actions to include objects and add a lookup table.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 24
akaterr55
Here's a single angle iron with chooseable sizes.  There are no adjustable radii.  Just a couple stretches for the legs and one for thickness.
Message 4 of 24
falconbird
dboard,
    I'm not sure I understand you. Don't know the difference between block table and the lookup table? If I go with the block table how do I add the dimensional parameters and constraints? Do you have a sample I can look at? Or can you modify the attached file I send early?
Message 5 of 24
Libbya
Either block properties table or lookups can be used to control dynamic parameters.  Lookups cannot control parametric constraints.
@falconbird wrote:
dboard,
There are a tremendous number of examples of both on this forum.  Dig in.  The AutoCAD help files also go into good detail.  There are free YouTube videos on dynamic blocks.
The number of items on the list makes the block irritating and dysfunctional.  I would split it into a column for width and a column for height so you don't have to click 400 times to get to the one at the bottom of the list.  Is Tw the thickness?
That angle block could certainly be done.  It would be a fair amount of work.
Message 6 of 24
m_rogoff
see attached, once you figure out the placement of the stretch polygons, it is fairly easy.
Message 7 of 24
falconbird
I guess I'm a little slow on this. I will keep at it and check out the AutoCAD help and go onto YouTube. Thank you for your help.
Message 8 of 24
m_rogoff
Why don't you just use the block I posted? I tried to save you the trouble. Is there anything else you need modified?
Message 9 of 24
Libbya
Here's a step-by-step screencast that shows how to set up your particular block with the various parameters and actions to adjust the geometry.  It also shows how to add a lookup to control the geometry.  You would need to fill out the table with the correct values for the various parameters to complete the block.
Message 10 of 24
falconbird
m_rogoff I look at what you sent. I appreciate you sending it to me but it's not exactly what I'm looking for as an end result.
Libbya this is exactly what I am looking for. Thank you for your help. I will work with this.
Thank you all for your help.
Message 11 of 24
falconbird
Libbya, sorry but one more question. Where did you get this video?
Message 12 of 24
Libbya
I made it using Autodesk Screencast.
Message 13 of 24
falconbird
Libbya, where did you get this vido?
Message 14 of 24
falconbird
sorry about me aksing a second time.
Would you send me a copy of it? If not I understand.
Message 15 of 24
Libbya
I did not 'get' the video anywhere.  As I just said, I made the video using Autodesk Screencast.  If you send me your e-mail in a private meassage I will e-mail the mp4 to you.
Message 16 of 24
dbroad
@Libbya,
Fantastic commitment (20+ minutes on the topic). Bravo. I hadn't been keeping up with the thread but had hoped that I had provided enough info so he could do the work without a step by step or without me doing the OP's work for him.
Message 17 of 24
thank you, best block ever!!
Message 18 of 24
m_rogoff
Thanks! I have similar blocks for steel Wide Flange, HSS, Pipe and Channel if you would like me to send it to you.
Message 19 of 24
Hi, yes please, I would love to to try them out.
Thank you
[email protected]
Message 20 of 24
Hi Matt.  I have been looking for C Channel blocks.  Would you be able to help me with this?
Thanks, Mike
