Dynamci Blocks with steel angle shapes
falconbird
falconbird
       Trying to create a steel angle dynamic block. Attached is a drawing showing the steel angle with its table showing sizes and length. Can't get it to stretch. Also don't know if I will have a problem with the radius of all the angle sizes. Using the sample files as a template. Please help me file in the blanks.
Replies (23)
m_rogoff
@Anonymous
 C and MC shapes.
 Cross section, front, side views
m_rogoff
I've attached a file containing steel sections and shapes, plus misc supporting blocks (weld, bolts, base pl, shear tab, etc) that I created using the same method @Libbya outlined in this thread. All steel sizes are from an AISC spreedsheet imported in the properties table.
I no longer use AutoCad so I am passing this forward and hoping someone else can use these!
--mr--
falconbird
Thank you.
Thanks for the blocks passing on.  Might have to modify them for layer properties and line types but the mechanics work great.  Thanks again.
