Dynamic Blocks Forum
distance constraint between curves in dynamic block
7 REPLIES 7
Message 1 of 8
481 Views, 7 Replies
Hi
I am trying to maintain a specified distance between curves during a scale parameter in a dynamic block, Im wondering if anyone have a solution for this?
Regards
Anthony
7 REPLIES 7
Message 2 of 8
zia_rehman
You can do this even by copying the whole set of Elbow in another visibility state and modify the sizes as required for your design.
For this idea it's like set of blocks in one dynamic block, i know you are looking for different way to solve.
Zia
____________________________________________________________________________
Please mark this post "Accept as Solution" if my reply solves the issue or answers your question.
Zia
Message 3 of 8
in reply to: zia_rehman
Thanks for you reply zia, I had considered visibility states but was put off by the sheer number of states to cover the entire range of sizes I need - thanks for the test sample...will make that work for now.
Regards
Anthony
Message 4 of 8
hwalker
I can't get the inside arc to stay at 25. It would probably take a good sit down to look through.
But here you go. Look at Visibilitystate0 and see what I've done. The block is called test1
Howard Walker
Left Handed and Proud
Message 5 of 8
in reply to: hwalker
Nice Job..hwalker, that gets me a step closer. tried to apply another distance parameter and scale action to the inside radius but didn't work..thanks for your help, much appreciated
Message 6 of 8
hwalker
Here you go. The block is updated and it now works.
It needed a scale action for the inner dashed arc. Then a stretch action needed to be added to Distance2 to stretch Distance3 and Distance3 then needed to be made a chained parameter. See the attached drawing.
You'll need to fiddle with the rotation parameter, but apart from that it should help you
Howard Walker
Message 7 of 8
You're an absolute legend hwalker...thanks for doing that. I will have a crack at the rotation and visibility states
Regards
Anthony
Message 8 of 8
hwalker
@Anonymous
Here you go. I managed to sort out the rotation. There was also a problem where the internal arc was moving out of position.
Howard Walker
Forma Design Contest
AutoCAD Beta
