Dynamic Blocks Forum
Automatically incrementing numbers within Attribute definition to a dynamic block
4 REPLIES 4
CAME7
162 Views, 4 Replies
I have a dynamic block made for a PV Panel that allows me to stretch and modify its size based on the manufacturer's dimensions.
In addition, I have set up an attribute definition that allows me to input a number to assign to each panel in numeric order (1, 2, 3, 4 etc) but currently, I have to do this for each panel manually.
Can something be assigned to the attribute definition to automate this?
I have attached the block in question.
Many Thanks
4 REPLIES 4
hwalker
in reply to: CAME7
@CAME7 A block properties table will do what you ask. See the attached drawing
Howard Walker
Left Handed and Proud
CAME7
in reply to: hwalker
Thanks for the speedy response
Ah! Didn't think of using a visibility block to do this
However, the number required could one day be 50 panels and the next be 250 - is there, not a way for it to automatically populate instead of creating each number within the visibility properties
hwalker
in reply to: CAME7
If you put the numbers into an excel file you can then copy the data and paste it straight into the block properties table.
In fact you could split it into groups of 10 using excel. See the image below
Unfortunately I don't have full AutoCad so cannot sort the table. You need to have a user defined column as the first column and I would probably call it number range. Then just paste the data from the excel file into the block properties table. See the image below for an example of the data
Howard Walker
CAME7
Brilliant, thanks for your help Howard!
Autodesk Customer Advisory Groups
”Boost
