Dynamic Blocks Forum
!!!!!Application reference missing: ACAD, to AcDbMaterial!!!!!
18 REPLIES 18
Message 1 of 19
1856 Views, 18 Replies
"Application reference missing: ACAD, to AcDbMaterial
Object reference missing: AcDbXrecord, to AcDbDictionary."
now i can't refedit the xrefs i work with please help me.
This is a serious problem!!!!!!! please reply if you are sure for 100% how to handle with this problem.
18 REPLIES 18
Message 2 of 19
This has nothing to do with DBlock, as far as I can determine. Don't
cross-post.
R. Robert Bell
wrote in message news:5524608@discussion.autodesk.com...
Message 3 of 19
I almost certain it is caused by those external dblocks!!!
Message 4 of 19
Have you run Audit on your drawings that are affected by this. Run it and make sure it is fixing errors as it goes.
Message 5 of 19
You only mention xrefs, not dblocks.
R. Robert Bell
wrote in message news:5524674@discussion.autodesk.com...
Message 6 of 19
Hello tlindell,
Yes but that didn't work. any other suggestions.
I already made wblock of the original drawing.
even that didn't work.
Please help me!!!
Message 7 of 19
Post that drawing here, I'll try to do something...
Message 8 of 19
I use autocad 2000/2000i and i can't refedit the drawing
after i attached it in a new drawing.
autocad 2007 no problems!
I appreciate your interest!
Message 9 of 19
Well, that's a problem. 2007 significantly changed how materials were
handled. So you are saying that a SaveAs of a 2007-base drawing down to 2000
causes 2000/2000i to complain?
Sorry I cannot help further, since I dumped 2000 about 5 years ago.
R. Robert Bell
wrote in message news:5529310@discussion.autodesk.com...
Message 10 of 19
Here is your cleaned drawing...
Message 11 of 19
thanks. I'll give it a try
Now i'm very curious, how, what did you do with it?
Message 12 of 19
What was the solution to this??
Message 13 of 19
gilab
Hello Quiz,
I see you have ignored the earlier requests for the specific solution for this problem. We just ran into the same problem and I would very much appreciate it if you would share the fix with me and the rest of the community!
Message 14 of 19
Hello there,
i did not get the answer from qiuz ether!!!
Message 15 of 19
Copy all geometry to a new drawing in your older version. Copy all of the layouts, use design centre if you have it.
Problem goes away. It's a nuisance, but that's the only fix that I'm aware of.
Message 16 of 19
I have encountered also the same problem? With error message:
Application reference missing: ACAD, to AcDbLinetypeTableRecord.
I tried both the audit and the copy to new drawing but those didn't work!?@#... I also tried to rename the block and purge, still not successful... anyone has any other brilliant idea on this? PLEASE HELP...
Message 17 of 19
The drawing contains Macros. I wblocked them out to a new drawing, then they seemed to disappear.
Try this.. not sure if it will help, or not. Message was edited by: sschwartz
Message 18 of 19
try my solution....
get suspect culprit
wblock
save to dxf /
import dxf back to main dwg
IT SOLVES IN MINE
I CAN REFEDIT,
NOTE BUT NOT TESTED TO XREFEDIT
i assume it would be ok
happy acad dears .!   :D:D:D
Message 19 of 19
filizcabuk
I found a 3D line in the block I made and when I fixed it, the problem was solved.
Forma Design Contest
AutoCAD Beta
