adding leader to block
Berrys_Cooling_Drafter
Message 1 of 24
I am not familiar at all to Dynamic blocks, so I need your detailed help.
I created a tag with attributes I want ta add a leader to point to whatever I am tagging. I need the leader to stay attached to the tag and have the option to flip to the other side depending on what direction I am tagging. If this is possible, can you please give me detailed instructions on how to do this?
thank you
Replies (23)
Message 2 of 24
pendean
Community Legend
Community Legend
Why not just use MLEADERSTYLE command to define a custom tag (if the default do not meet your needs) and use that instead? You can easily make that tag leaderless or leader-ful as you wish all day long after that with MEALDER command and all o the mleader tools in the program.
Message 3 of 24
that wont help me I need to have the tag I set up.
I want to add a leader that I can change the placement  when needed
Message 4 of 24
vinodkl
@pendean is right. Instead creating a dynamic block with leader you can utilize the multi leader. As you have already created the tag block, type in the command MULTILEADER(MLD) and the select "option" and then the "content type" next "block" after that type in the block name given to the tag. Now you will have the tag with leader which acts more intelligently.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 24
followed your instructions it did not give me a leader to my block
Message 6 of 24
vinodkl
Type in the command MLD and try to draw mleader. Does the mleader contain your tag or not?
if not then attach you tag, so that I can help you out.
Message 7 of 24
 how do I attach my tag?
Message 8 of 24
vinodkl
Sorry about that my bad. Attach the drawing containing the tag.
You have the option to attach the file if you can scroll down when replying back you will see the attachment option.
Message 9 of 24
see attached
Message 10 of 24
Libbya
Is this what you are wanting?
Message 11 of 24
so every time I insert the tag I need to do what you're showing if I want a leader?
Message 12 of 24
Libbya
No.  I created a multileader style.  Set that style current and add as many of them as you like.  Add as many leaders as you like to each multileader.
Message 13 of 24
Libbya
In other words you would no longer use the tag block outside of the multileader.  Whenever you wanted to insert a tag, you would insert a mulileader of that style.  Set any specific leader properties within that style.  If you want a tag without any leader, then remove the leader in the same way that I added them.
Message 14 of 24
Libbya
If you primarily want the block not to have any leader but want the option to add a single leader for special circumstances, that can also be done as a dynamic block.
Message 15 of 24
that was what I want. so can you please show me how to do that so I can have the option of having a leader on the right side  the left, both and none.
thank you I greatly appreciate your time and effort to help me out
Message 16 of 24
Libbya
Honestly it is harder and less functional than using multileaders, but here you go:
Message 17 of 24
Wow thank so much I really appreciate your help!!
where can I learn to do that and understand what you're doing in every step?
Message 18 of 24
can you please tell me are you using polar stretch or not I am trying to follow what you are doing I am not getting the same results
Message 19 of 24
Message 20 of 24
Libbya
If you use lines rather than a polyline for the two segments that are 0 width, then you can use a polar stretch on both the arrow point and the line endpoint that ends at the arrow point.
