Message 1 of 8
07:03 AM
Don't know if this is even possible. We are trying to Stretch Objects/Dynamic Blocks in Model Space using Stretch Command, but we need to be able to stretch both at the same time. The reason behind this is our Dynamic Block has Extrusion Type and Length included, but we are having to adjust the Dynamic Block after Stretching the object to align with holes on our Object. We then Data Extract Ext. Type/Length so that there can be a Cut List per Extrusion loaded in our Tiger Stop, making it easier for the shop to prepare for Panel Releases. If this isn't feasible, are there any other options. I've attached a DWG with our Panel and Dynamic Block. Please HELP.
