adding leader to block
Berrys_Cooling_Drafter
Message 1 of 24
I am not familiar at all to Dynamic blocks, so I need your detailed help.
I created a tag with attributes I want ta add a leader to point to whatever I am tagging. I need the leader to stay attached to the tag and have the option to flip to the other side depending on what direction I am tagging. If this is possible, can you please give me detailed instructions on how to do this?
thank you
Replies (23)
Message 21 of 24
what did you use?
didn't you use for all lines a polyline?
Message 22 of 24
can you send me the block
Message 23 of 24
Libbya
No I won't send the block.  In the screencast I use a polyline for each.  You can use either polylines or lines for the ones that are 0 width and in retrospect it would have been easier to use lines.  If you use lines, you can use a polar stretch for both arrow and line endpoint.  If you use polylines, you will need to use a polar stretch for the arrow and an additional stretch for the 0 width polyline.  There are a lot of free Youtube videos covering the basics of dynamic blocks.  You might want to avail yourself of that resource as this is fairly basic stuff.
Message 24 of 24
ok I respect you not wanting to send me the Block. again I thank you for you help
