Default text in a Field with look up parameter not visible in block
dee
dee
Hope I have posted to the correct area.  Apologies if not.
I have created a Title Block with a number of  text fields - these fields contain a liner and look up parameter with a look up action attached.  Which allows me to select a number of options from a drop down menu when exited out of the block editor.
In addition, I have applied different attributes to each line of text.
I successfully achieved this, but some time ago, and need to do it again.
However,  the default text for the new field is not visible and I cant see why.  Although the look up drop down is visible.
Really appreciate anyone's help as this is sending me crazy.  😞
Regards
Dee
ojuris
why you post picture instead of file with block?
dee
I posted the JPEG rather than DWG because there is too much company data within the file to remove quickliy.
I will create a example file without this data and uploaded.
Regards
Dee
vinodkl
Did you use the command ATTSYNC on the block to sync the attributes??
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
dee
hi,
I found out about that this morning so tried it and it didn't affect it.
Also made sure I Regen.
However,  was just creating a file to upload - inserted the block without important information and this field is now visible and working.
I am a newbie , I still don't understand why it would suddenly appear now.
I am so so sorry if I have wasted your time 😞  .  Thank you for being so quick in your response.
Dee
Do
vinodkl
No worries Dee 😊 I am glad that your problem got solved
